Hi:
I have a group of dimension objects gather up by a selection set (objSS). I can screen each one one of these dimension by the lines
Dim objDimStyle As AcadDimStyle
For Each objDimension In objSS
Next
How is possible to assign the property Dim Style to each one of my objDimension to an Style that I have already created?
I can not find this property available for my objDimension
Thanks in advance
Rafael
Cast objects explicitly, always
Dim oEnt as AcadEntity
dim objDimension as AcadDimension
For Each oEnt In objSS
set objDimension=oent
If Typeof objDimension is AcadDimRotated then
dim acDimRot as AcadDimRotatedDimension
set acDimRot=objDimension
'then something similar:
acdimRot.Style="myNewStyle"
else if Typeof objDimension is AcadDimAligned then
dim acDimAlign as AcabDimAlignedDimension
set acDimAlign=objDimension
acDimAlign.Style="myNewOtherStyle"
Next
ETC,
Sorry, Just from the top of my head without VBA Editor,
digg deeper inside all dimension types then,
~'J'~
well, here is the code, see how it works for you
Option Explicit Public Sub ch_dimstyle() Dim gpCode(0) As Integer Dim dataValue(0) As Variant Dim dxfcode, dxfdata Dim oEnt As AcadEntity Dim oDim As AcadDimension Dim setObj As AcadSelectionSet Dim setColl As AcadSelectionSets Dim setName As String Dim objEnt As AcadEntity Dim stName As String stName = "MyNewDimStyle" If Not IsDimStyleExist(stName) Then MsgBox "Dimstyle does not exist, create one before..." Exit Sub End If On Error GoTo Err_Control gpCode(0) = 0: dataValue(0) = "DIMENSION" dxfcode = gpCode: dxfdata = dataValue setName = "$DIMENSION$" With ThisDrawing Set setColl = .SelectionSets For Each setObj In setColl If setObj.Name = setName Then .SelectionSets.Item(setName).Delete Exit For End If Next Set setObj = .SelectionSets.Add(setName) End With setObj.SelectOnScreen dxfcode, dxfdata setObj.Highlight True MsgBox "Selected: " & CStr(setObj.Count) & " objects" For Each oEnt In setObj Set oDim = oEnt If TypeOf oDim Is AcadDimRotated Then Dim acDimRot As AcadDimRotated Set acDimRot = oDim acDimRot.styleName = stName acDimRot.Update ElseIf TypeOf oDim Is AcadDimAligned Then Dim acDimAlign As AcadDimAligned Set acDimAlign = oDim acDimAlign.styleName = stName acDimAlign.Update ElseIf TypeOf oDim Is AcadDimDiametric Then Dim acDimDia As AcadDimDiametric Set acDimDia = oDim acDimDia.styleName = stName acDimDia.Update ElseIf TypeOf oDim Is AcadDimRadial Then Dim acDimRad As AcadDimRadial Set acDimRad = oDim acDimRad.styleName = stName acDimRad.Update 'ElseIf TypeOf oDim Is ETC... 'Else ... End If Next ThisDrawing.Regen acActiveViewport Err_Control: If Err.Number <> 0 Then MsgBox Err.Description End If End Sub Function IsDimStyleExist(styleName As String) As Boolean IsDimStyleExist = False Dim oDimSt As AcadDimStyle On Error Resume Next For Each oDimSt In ThisDrawing.DimStyles If StrComp(oDimSt.Name, styleName, vbTextCompare) = 0 Then IsDimStyleExist = True Exit For End If Next End Function
~'J'~
