Hi There,
for years I have been using an VB program to retrieve beam (simple quare block with scaled Z value) lengths from modelspace. In modelspace a construction is shown made out of three different blocks. 90x90xL, 90x45xL and 45x45xL. where L is a scale Z dimension. The method I use I describe also in the tutorial below:
This method works good but has a big few setbacks.
1. I cannot use flatshot or create other 3d views showing the beams. They are simply left out
2. To change the length I cannot use 3DSTRETCH (or pull an arrow) but I need to go into properties and change the Z scale.
What I'd like to accomplish?
a. Could I replace my blocks by a BOX entity (or extrusion) to create beams. (I know AutoCad doesn't allow to retrieve Solid Extrusion geometric values. So I guess this is no option.
b. Would it be possible to create a dynamic block from a 3d extrusion with a LENGTH value. (If this is possible than I need some input in how to do so. I've looked but didnt founds a solution like this')
c. Any alternatives I havent thought of. ....
Help is appreciated. I hope one of you can provide me with a clever solution.
Thanks in advance,
Wiebe
See this link:
http://www.cadtutor.net/forum/showthread.php?37494-getting-3dSolid-Box-properties-using-VBA.../
I attached a VBA sample routine (post # 10) that does a pretty good job for generic rectangular solids.
