VBA
Discuss AutoCAD ActiveX and VBA (Visual Basic for Applications) questions here.
All layers locked except the active layer chosen in combobox?
4 REPLIES 4
lanieuwe
667 Views, 4 Replies
Hi!
Can someone help me a bit?
2 questions.
I have a form with a combobox and a commandbutton.
  1. All layers in the layermanager must be locked except the active layer chosen in the combobox.
 I try it with this code but it’s not the right solution.
Private Sub CommandButton1_Click()
Dim layer As AcadLayer
'check if all layers are locked
If layer.Lock = False Then
layer.Lock = True
'make the layer selected in the combobox current
ThisDrawing.ActiveLayer = ThisDrawing.Layers.Item(ComboBox1.Text)
End Sub
Private Sub UserForm_Initialize()
  Dim layerColl As AcadLayers
 Dim LayList As String
  ' all layers locked
 For Each layer In ThisDrawing.Layers
    layer.Lock = True
Next
  'fill combobox
 Set layerColl = ThisDrawing.Layers
 For Each layer In layerColl
    ComboBox1.AddItem layer.Name
 Next
 End Sub
 2. When I choose the for next method to lock all layers (40 layers) it’s very slow.
Is there a solution for that?
Gr. Laszlo
4 REPLIES 4
lanieuwe
in reply to: lanieuwe
The first question I answered my self. I turned te code into this:
On Error Resume Next    'handle exceptions inline
Dim objlayer As AcadLayer
For Each objlayer In ThisDrawing.Layers
    objlayer.LayerOn = False    'turn off all the layers
Next objlayer
Set objlayer = ThisDrawing.Layers.Item(ComboBox1.Text)
If objlayer Is Nothing Then
    MsgBox "layer does not exist"
    Exit Sub    'exit if layer not found
objlayer.LayerOn = True 'turn on the desired layer
End Sub
  'fill combobox
 For Each objlayer In layerColl
    ComboBox1.AddItem objlayer.Name
 Next
 End Sub
 It is working but,
My second question: Why is it so slowly to locked all layers? Smiley Sad Is there a solution?
gr Laszlo
Hallex
Just on a quick glance Why are you iterating through the layers collection this way, it's a reason of slow work: For Each objlayer In ThisDrawing.Layers objlayer.LayerOn = False 'turn off all the layers Next objlayer Better yet declare layer collection first instead, i.e.: Dim objLayers as AcadLayers Set objLayers=ThisDrawing.Layers Then do the same: For Each objlayer In objLayers objlayer.LayerOn = False 'turn off all the layers Next objlayer
_____________________________________
C6309D9E0751D165D0934D0621DFF27919
lanieuwe
in reply to: Hallex
Is this what you mean?
Next objlayer
Dim objLayers As AcadLayers
Set objLayers = ThisDrawing.Layers
Next objlayer
End Sub
  'fill combobox
 Next
 End Sub
 It still slow!
gr. László
lanieuwe
Above wrong code sorry!
See this code it's still slow (For next is slow)
Next objlayer
End Sub
  'fill combobox
 Next
 End Sub
 help?
”Boost
