I've been using the ado_lisp method to create a table and populate it from an access database with mixed results. Does anyone have a VBA routine to create a table to share or a good source of information? Pulling from a Database would be a bonus. I've been searching for a couple of days and haven't found a good source of info so now I'm begging!
Now I'm struggling with creating an insertion point for the table. I'm using:
varPnt = ThisDrawing.Utility.GetPoint(Prompt:="Pick Insert Point:")
Set Table = ThisDrawing.PaperSpace.AddTable(varPnt, RowCount, Numcolunas, 0.25, 1.2)
BUT I get
Run-time Error -'2145320928 (80210020)'
User Input is a keyword
and when I choose Debug the line varPNT = ..... is highlighted.
If I ignore and hit the RUN button and switch back to the drawing window the prompt is there and after selecting an insertion point the table is inserted perfectly.
Does anyone know what causes this and how to correct?
I have no problem running this:
varPnt = ThisDrawing.Utility.GetPoint(Prompt:="Pick Insert Point:") Set Table = ThisDrawing.PaperSpace.AddTable(varPnt, 5, 5, 0.25, 1.2)
Wound up with this:
ThisDrawing.Utility.InitializeUserInput 1
v = ThisDrawing.Utility.GetPoint(, vbCrLf & "Pick a corner point: ")
varPnt1(0) = v(0)
varPnt1(1) = v(1)
varPnt1(2) = v(2)
Set table = ThisDrawing.PaperSpace.AddTable(varPnt1, RowCount, Columns, 0.25, 1.2)
