Use a filtered selection set to get the top-level XRefs inserted in the
drawing. Each one of those objects will have the Path property, which you
can use to load the external drawing and perform the edits. You can opt to
fully load the external drawing or use ObjectDBX. Details on all of this can
be found by searching this ng.
R. Robert Bell
"manoj_vest" wrote in message
news:18350553.1084780297277.JavaMail.jive@jiveforum1.autodesk.com...
Do any body know how to access the external reference object. I not only
require to access all the external references in a drawing, but also the
definition for thoses external references in the drawing. I aslo want to do
some changes in the original file which has been referenced in the current
file. Is this possible?
Thanks in advance
Manoj
