Hi every body
this question very important for me , i tried to solve it by my slef with 1 year along but i can't to find any solution for it
my problem
i have 3 attribute in one block , i made 3 options for visibilty1
so i need in visibilty (1) i can show only the text 11
and i need in visibilty (2) i can show only the text 22
and i need in visibilty (3) i can show only the text 33
see my attach and you will understand me
thx for ur help
hi.
i checked your bloc it work fine. But i dont know why all the att is show.
I have delete all your block and i have used the insert bloc --> i have only one attribut showed.
check the ATTMODE but i dont know why this.
can you test with the var. system ATTREQ at 0 ?
or create a wbloc with you block and créate a new dwg and insert your bloc from the file.
sr for my english : so.
1 - in command ligne : 'wbloc' press Enter and sélect your bloc inserted. check the name of the bloc in Name (in the new windows)-> save it. (see et1.pdf)
2 - Close the dwg and in the Menu File : New
3 - in the new dwg : command ligne : insert ENTER (sr for mee : inserer so try the command i ENTER)
--> in the windows click on the button Add (sr my acad is in French) (see Et2.pdf)
--> choose the file saved in part 1 --> Enter and insert it on the dwg.
if this works ok , but if not.. i dont know why.
did you understand my question ?
i think your solution is for inserting block but my question for how can i show two attributes in dynamic block with two visibilty options
i hope you will understand me
sorry for my english
