I get a beautiful vehicle envelope but no wheel path. where is the wheel path setting, it critical.?
Solved by viji.kumar. Go to Solution.
I hope the following article helps:
http://knowledge.autodesk.com/article/Vehicle-Tracking-displaying-wheel-paths
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
Hi Viji,
Thanks for your article, it can change the path setting to create new path, however, do you know how to change the setting for existing path??
Select the existing path, use the Vehicle Tracking Properties command button on the right side of the context ribbon, and click on the reports tab.
All the options in the settings command are available on the path.
Nigel Peters
This solution seems to show the wheels but not the wheel path. Am I missing something?
I followed Nigel's method to find the settings menu then I ticked the 'chassis outline' box and the wheel path showed up.
I agree, I think it's because it's a combined wheel path and not a separate front wheel path and back wheel path. Is there a way to turn on the front wheel path and the back wheel path and set them to different colors?
Thanks!
