I have the vehicle tracking add in ribbon installed on AutoCAD 2015. When I try selecting any of the features on the ribbon, the message box comes up with Unknown Command. Is there anything I need to do, to get these to work?
Solved by viji.kumar. Go to Solution.
Our IT team installed it, probably the latter. Is there a way to fix it from there, or do they have to unistall it and reinstall it as it was a separate piece of software?
Have you tried using "APPLOAD" to load the following arx file: atra200_arx.arx. This might fix the problem.
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
Thanks, that has worked to a degree. Have now realised I have Vehicle Tracking 2014 and AutoCAD 2015 that don't work together. Will it work with AutoCAD 2013?
Hello
For ACAD 2014, you need Vehicle Tracking 2014 !
For ACAD 2015, you need Vehicle Tracking 2015 !
etc ...
Patrice BRAUD
Hello
YES I know that ARX are the same between 2013 & 2014, so a lot of 2013/2014 developments are running on both platforms !
But for me (and maybe for the OP), the main question is : Does Autodesk support officially Vehicle Tracking 2014 on ACAD 2013 ?
Thanks in advance for your official answer !
Patrice BRAUD
Hi Patrice
You asked: "Does Autodesk support officially Vehicle Tracking 2014 on ACAD 2013?"
Yes, we do. It is stated on the Vehicle Tracking free trial page:
Hello
I am a stupid boy, I don't look at the Vehicle Tracking Page ZERO !!
OK THKS, I have learned something today !
Regards, Patrice
Patrice BRAUD
Patrice
I don't think you are. It is always a good idea, IMO, to verify specifications and entitlements before embarking on installations and stuff.
Thanks for requesting a clear statement.
