My C Drive but the dust and I lost all my Survey Data Bases. I still have all the dwgs but I am wondering if the survey Database can be recreated with just the dwg. Or is the dwg still good with no Survey Data Base?
dj
Solved by viji.kumar. Go to Solution.
Hi
You cannot recreate the survey database from the drawing itself, but the drawing may be good enough to work with. It all depends what was in the survey database and how it was processed (i.e. what has been inserted in the drawing), etc.
If points from the survey have been added from the survey database to the drawing in the past, you will have the points self contained within the drawing. However, you won’t get the observations (the actual measurements, e.g. the distances and angles actually surveyed in the fields).
Furthermore, you may only have lost the reference to the survey database. Please check if the database is still somewhere on your drive. You could try searching for .sdbx files on your drive and see if anything shows up. Then it will just be a matter of replacing the folder at the right location or repath correctly in C3D.
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
Kind regards
Viji
