Round 2
I found using SendCommand below I am able to get the intended results.
Can/should this be done w/o having to use SendCommand?
Chris
Public Sub DimOrdinateTest()
Dim P1(2) As Double
Dim P2(2) As Double
Dim P3(2) As Double
Dim P4(2) As Double
Dim CirclePt(2) As Double
Dim MyLine As AcadLine
Dim MyCircle As AcadCircle
Dim MyDimOrdinate As AcadDimOrdinate
Dim MyUcs As AcadUCS
Dim currUCS As AcadUCS
Dim OrdPt1(2) As Double
Dim OrdPt2(2) As Double
Dim x1 As Variant
Dim x2 As Variant
P1(0) = -500: P1(1) = 500
P2(0) = -500: P2(1) = 600
P3(0) = -400: P3(1) = 600
P4(0) = -400: P4(1) = 500
CirclePt(0) = -425: CirclePt(1) = 500
OrdPt1(0) = CirclePt(0): OrdPt1(1) = CirclePt(1)
OrdPt2(0) = CirclePt(0): OrdPt2(1) = CirclePt(1) - 10
Set MyLine = ThisDrawing.ModelSpace.AddLine(P1, P2)
Set MyLine = ThisDrawing.ModelSpace.AddLine(P2, P3)
Set MyLine = ThisDrawing.ModelSpace.AddLine(P3, P4)
Set MyLine = ThisDrawing.ModelSpace.AddLine(P4, P1)
Set MyCircle = ThisDrawing.ModelSpace.AddCircle(CirclePt, 5#)
ThisDrawing.SendCommand "ucs" & vbCr & "n" & vbCr & P1(0) & "," & P1(1) &
vbCr
x1 = ThisDrawing.Utility.TranslateCoordinates(OrdPt1, acWorld, acUCS,
False)
x2 = ThisDrawing.Utility.TranslateCoordinates(OrdPt2, acWorld, acUCS,
False)
ThisDrawing.SendCommand "dim1" & vbCr & "ord" & vbCr & x1(0) & "," & x1(1) &
vbCr & x2(0) & "," & x2(1) & vbCr & vbCr
ThisDrawing.SendCommand "ucs" & vbCr & vbCr
End Sub
"Chris Picklesimer" wrote in message
news:4A0FA977797091B8C60302779760E04A@in.WebX.maYIadrTaRb...
> Here is my situation I get four points in modelspace, while in the WCS,
> that represent a 100,100 square with P1 being the lower left point. I
> create a 10" dia. circle 75 units to the right of P1. I create an
ordinate
> dimension but it dimensions from 0,0 of the WCS. I want the dimension to
be
> relative to P1. I have seen threads saying that
> ThisDrawing.Utility.TranslateCoordinates is required. I have tried using
it
> but am still not getting the results I want. Below is some code explained
> in this thread. How would I apply
> to this code so that my ordinate dim be 75 instead of 425? Thanks.
> Chris
> Dim P1(2) As Double
> Dim P2(2) As Double
> Dim P3(2) As Double
> Dim P4(2) As Double
> Set currUCS = ThisDrawing.ActiveUCS
> On Error Resume Next
> Set MyUcs = ThisDrawing.UserCoordinateSystems.Item("Temp")
> If MyUcs Is Nothing Then
> ThisDrawing.UserCoordinateSystems.Add P1, P4, P2, "Temp"
> ThisDrawing.ActiveUCS = ThisDrawing.UserCoordinateSystems("Temp")
> Else
> ThisDrawing.UserCoordinateSystems("Temp").Delete
> End If
> Set MyDimOrdinate = ThisDrawing.ModelSpace.AddDimOrdinate(OrdPt1, OrdPt2,
> True)
> ThisDrawing.ActiveUCS = currUCS
> End Sub
