Workpace Folder Autosync
Hi all,
We are looking for a way to automatically sync certain folders in Vault to the Local Workspace.
We are attempting to create templates that live in Vault, but right now there is no way that i can find to automatically push certain folders to local machines.  This forces all users to "Get" the templates folder, every time there is a change to the template, or a new template is added.
Thanks!
7 Comments
ihayesjr
Have you tried using the Workspace Sync utility?
Codered741
Workspace sync wants to delete the files, as I do not have them checked out.  I am also looking for an automatic way to do this for all users, without them having to go into the client and get them manually.
I am looking at this as wel for a long time. At the moment there is no standard solution for it.
I like to use vault to deploy templates and the design data of inventor.
Biggest problem is the user. It is his dicipline that controls the updates on his system. This should be done automaticly after start of Vault.
ryan
Our "Vault Mirror Plus" utility can do this and is entirely free for anyone on Vault Pro 2016.
We specifically built this tool because we had customers with the exact problem you state - maintaining up-to-date local copy of templates.  Unfortunately Workspace Sync was not the answer because it will not pull down any new files, it will only update the ones you already have locally, therefore, we built our own utility.
https://www.solidcad.ca/vault-toolkit/vaultmirrorplus/
philip.s
Senthil_Kumar
Thanks for sharing your Idea. We use this forum to guide product development and help users in the best way we can based on voting. We occasionally merge Ideas or archive old ones to keep the forum working properly- it ensures there is room for people to review new Ideas and that the most relevant and meaningful ones can gain votes. We’re archiving this Idea because it's been on the board for well over a year and hasn't received many votes from the community. If you want to raise it again and try to gain more support, you're welcome to do so. We’ve found that pictures and mock-ups can help get concepts across and win more votes from other users. If you have questions or see a connection between this Idea and others, let us know. - Vault product team
Senthil_Kumar
Status changed to: Archived
