Gentlemen,
Issue:
Read only files or "non-checked out" files, continue to be prompted for saving inside of an Inventor assembly model. Why is this happening? I know the little messages (see Vault messages below) are supposed to let you know the file is not being saved back to Vault, but something is happening. Somehow the files become edited out of turn, which means they're being saved locally somehow. Then the Vault file and the workspace file are out of sync.
Solution:
Can we just remove the Vaulted "read only" files from the assembly save dialog all together?
Is it possible to not change the local file in the certain way that makes Vault see it out of sync?
I have Vaulted released files that are part of assemblies that are checked out for editing and somehow the parts of the assembly that are not checked out seem to always become out of sync.
Also, some of these parts are iParts.
Please give this post Kudos if you have the "read only" file out of sync with Vault issue.
Autodesk: Please consider my request. Thanks.
Vault Messages:
"Write enable (not checked out from Vault)"
"'XXXXXX.iam' is currently locked. Do you want to continue editing anyway? Your changes will not get saved to the Vault."
