Description
This feature doesn’t work with Buzzsaw in a way which produces a smooth workflow. The problem being that when a file is Shared to Buzzsaw, there is no way to send off an email notification from Buzzsaw at the same time. This means that the user then has to log into Buzzsaw or an email client and do the email notification manually.
Impact
Double work is required for a workflow which should be able to allow for this in a single step. At the moment it is best if the user uploads the files directly to Buzzsaw and send the email notification at the same time. This is not ideal, but currently it provides a more efficient workflow.
Severity
Medium
Solution
Force Buzzsaw to prompt for the email notification dialog at the time of sharing the file/s.
