VAULT LIFECYCLES TRANSITION CRITERIA (LOGIC OPERATORS)
Greetings,
In the transitions between lifecycle states, by default when several properties criteria are used, they must default fulfilled all at once (AND behaviour).
Vault should have the option to use logic operators (AND, OR, XOR...) between the different properties used.
For example:
Category Name contains "Documents" OR "Technical"....
This feature would be very useful for security and control reasons.
Thanks!
17 Comments
mark.cloyed
I tested your request, and would offer some clarification.  My testing was done in 2014 and 2015.  I find that within a single criteria, you can specify the 'OR' and 'AND' booleans for values.  As you say, if multiple criteria are listed, they are always evaluated in an 'and' situation.  I would agree with you that we have desired a way to use multiple criteria in an 'or' situation.
Mark
jeamy.baena
Hi, Mark
Thanks for your feedback!.
Yes, I agree with you. Posibility to use logic operators with differentes properties.
e.g.
marina.collet
Hi mark,
You stated
How exactly do you do that (I need a transition to be limited to idw or ipn file but I did not manage to get it to work)?
xavier_dumont1
YounesYammouri
YounesYammouri
Status changed to: Accepted
jeamy.baena
Greetings, Mr. Yammouri
Excellent news!
What vault release are you planning to implement this idea?
Thanks!
YounesYammouri
This capability has been implemented with Autodesk Vault 2019.
Smiley Very Happy
jeamy.baena
Smiley Very Happy Excellent!
akosubek
@YounesYammouri, you reported, that this would be implemented in Vault 2019. - I am running an installation of that, but cannot find an option to logically link transition conditions in any way. - Was this feature dropped, again?
YounesYammouri
No it is not dropped. Starting with Vault 2019 you can now add operator within the value. See image below:
akosubek
@YounesYammouri, okay, then I seem to have misunderstood: As of the clarification by @jeamy.baena in https://forums.autodesk.com/t5/vault-ideas/vault-lifecycles-transition-criteria-logic-operators/idc-... I assumed, that a logical connection between multiple, different property checks would be possible now.
So, currently, it is only possible to check for multiple conditions within one property, but not - for instance - if property A is set if and only if property B is set?
YounesYammouri
@akosubek Correct, operators (AND, NOT, OR) within the same property are supported starting from 2019 release. If you have several criteria with different properties it will be criteria 1 AND criteria 2 AND criteria 3 as condition for the transition.
http://help-staging.autodesk.com/view/VAULT/2019/ENU/?guid=GUID-B4443A39-A621-4E14-8A11-484EFBF3DB90
xavier_dumont1
This idea is flagged as "Complete" but there is 1 specific case where today there is no solution.
- Use an operator for empty value.
For example:
Set a transition criteria: "Change order state" IS "Approved" OR EMPTY
Useful if you want to be sure the ECO is on the state "Approved" if an ECO exist, but give the opportunity to change state if there is no ECO.
Is it considered as a new IDEA (because the original description of this idea perfectly answer this case). Thanks in advance.
stef.castelijns
@YounesYammouri
This boolean functionality only seems to work with Vault standard properties. I'm trying to add a boolean operator to a custom property, but it just doesn't work. This custom property has a list of predefined values.
Can you comment on this please?
br.sbrava
Any updates on this? This issue pointed by @stef.castelijns remains a problem here.
