Vault, Copy design and "Read only" categories
Gentlemen,
I'm having an issue with Vault where I have a library of standard assemblies that are used by numerous designers over a network. This standard assemblies category is marked "Read only". The designers use these standard assemblies as a "starting point" for a new design. The standards would be modified to become new assemblies. The problem arises when the designers use "Copy design" to copy the standard assembly to a location where they can modify it. After using the "Copy design" tool, we are noticing that the category is being copied as well. This does not allow them access to edit their "New" designs because it is copying tha "Read only" category. It would be a great enhancement if we were given the option of changing the category and state of a part or assembly that is being copied, when the 'Copy design" dialog appears.
Little help?
4 Comments
ihayesjr
tmoney2007
You could use the same category for standard parts and custom parts, that way, when you create a copy outside of the library, they have write access.
You may end up with extraneous lifecycles in one or both instances but it can be dealt with.
File category rules per folder (or at least "library" or "not library" could remedy this as well.
ihayesjr
olearya
A solution to this was implemented in 2015 R2 version of Copy Design where users can maintain current document category OR reset to default file category.
