While the batch print function in Vault 2015 seems to be, so far, vastly improved... the individual visualization print settings took a step backward. I don't know about 2014, I go back to 2013. Used to be, when you printed a visualization from either file or item, Vault remembered the settings you used the next time you printed. For example, if I printed to a pdf file using my default settings.... next time I printed it was still on pdf with those settings. All you had to do was hit enter. You could very quickly print out a bunch of different files from different locations without the batch plot.
In 2015, the print feature reverts to whatever your default printer settings are ( I assume from Control Panel), and you have to reselect the print settings you want with each visualization you print. Added keystrokes, added time = money down the drain. Please look into what changed and consider putting it back the way it was in 2013. Thank you for your support.
