Vault Forum
Welcome to Autodesk’s Vault Forums. Share your knowledge, ask questions, and explore popular Vault topics.
Use Vault Path property to define category
8 REPLIES 8
Message 1 of 9
746 Views, 8 Replies
In Vault objects have a property called path. I like to use the property in a rule when determin which category the part is.
For example:
If path contains "LIBRARY" category_name = "Library parts"
If path contains "DESIGN" category_name = "Design parts"
If path contains "Content Center Files" category_name = "CC parts"
In this way a user only has to place the part at teh right location on disk. During initial check in it will get the correct category automaticly.
Tags (1)
Labels (2)
8 REPLIES 8
Message 2 of 9
ihayesjr
Irvin Hayes Jr
Sr. Product Manager
Autodesk, Inc.
Vault - Under the Hood Blog
Message 3 of 9
xavier_dumont1
Any news regarding this? It's really a major issue (in my opinion) regarding assigning a specific lifecycle for Content Center Files.
Actually the solution bellow is not a good one regarding custom parts from Content Center and Frame parts.
https://www.youtube.com/playlist?list=PL9A6632DDBF5C9661
Thanks in advance
Message 4 of 9
ryan
This functionality needs to be added to vault.  Anyone who has ever tried to implement vault across multiple divisions in a company can speak to how important this functionality would be.
Vault allows us to display the "Path" as column in the UI, so why no love to use it within a categorization rule?
While using templates with a custom iProperty and/or Data Standard help, there are many situations where it does not - categorization by path would be the cleanest solution.
P.S. Depending on the customer and their folder structure, this may also help another issue I have with deploying vault across multiple divisions which is the ability to distinguish the "type" of DWG file.
-Ryan
Ryan Small
SolidCAD (Autodesk Reseller)
Ryan Small
National Team Leader, Data Management and Software Development
SolidCAD, a Cansel Company (an Autodesk Platinum Partner)
www.solidcad.ca
Message 5 of 9
ihayesjr
The Vault Data Standard feature can be used to accomplish this.
Irvin Hayes Jr
Sr. Product Manager
Autodesk, Inc.
Message 6 of 9
ThomasRambach
in reply to: ihayesjr
Why can't this functionality be part of the core product?
Message 7 of 9
cbenner
in reply to: ThomasRambach
Message 8 of 9
ThomasRambach
in reply to: cbenner
I haven't seen anything of the if, then else nature for this. @cbenner
Message 9 of 9
The request wasn't really solved.
Using the data standard isn't a nice way to work with vault, I think personally.
Beside the creation and management of the scripts to all clients, updating to a new release of Vault can generate extra work as well. If they don't work fine, you have to solve it yourself. Hints and how-to are given by multiple sources but you have to solve it yourself.
It should be a feature inside Vault, not in an add in.
