Use path as a condition
Can you add the possibilité to use the path of the file for a condition (rules, transition).
This will be very usefull in this case:
Departement A works in $\designs\DepA => all files must fall in a DepA Category
Departement B works in $\designs\DepB => all files must fall in a DepB Category
Thanks in advance
5 Comments
ihayesjr
Have you tried using Data Stanadards to see if this will do what you are requesting?
john.laidler
The file path is a property within Vault, but it doens't work with file rules.
We would also love this addition to Vault.  That way we can have files that are being added to a certain folder, be automatically assigned to a category.
masureb
For those you want to have this implemented, here is another post with similar need:
https://forums.autodesk.com/t5/vault-ideas/assign-category-per-folder/idi-p/3609610
philip.s
YounesYammouri
This idea is available in Autodesk Vault 2020.2 Update. See also the Vault 2020.2 Update help for some of the details:
http://help.autodesk.com/view/VAULT/2020/ENU/?guid=GUID-C8D0D903-30C3-456E-83BF-9E8B9F47D2F6
