Once a file\folder is replicated from one site to another, the challenge is to unreplicate.
Currently there appears to be 2 options to unreplicate a file.
1) In the ADMS Console, edit the "Replicated Folder" and untick the folder that you want to unreplicate, then delete the file(s) from the vault, re-add it to the "unreplicated" folder. This will prevent the file from being replicated in future
2) Disable the Vault on the site, delete the local filestore, Enable it. This can be dangerous if the file is not present on at least one other site. Its OK if you know all files are replicated to at least one site.
The wish is to untick a folder in the "Replicated Folder" dialogue for that site and for the ADMS Console to check to see if that file appears on another site before allowing the Admin to unreplicate the folder. Once the check is completed, the files in the selected folder are removed from that sites filestore.
If you think this would be a useful enhancement, add a comment to this thread...
