UDP Mapping
UDP Mapping
HI,
   If I'm not wrong, at this time, Vault is able to map and import existing iProperties coming from "User Defined Property" property set only.
If for some reason or particular customization you need to create your own PropertySet with custom iProperties, you will not be able to import them into Vault UDPs.
I think it would be very useful to extend this feature and allow administrators to map iProperties from any Property Set.
Just for an example, with this feature available, you'll be able to import into vault the "IsCustomPart" iProperty that's simplify rules to understand if a ContentCenter part is a "real" CC part or not.
Thank you in Advance
6 Comments
tmoney2007
I guess using a custom iProperty wasn't an option?  You can map those.
m.sabotto
I know how mapping works.Smiley Wink
The iProperty "IsCustomPart" is created by Inventor, but it is placed into a different PropertySet than "User Defined Property" which is the Only PropertySet you can use to pick up iProperty and map to UDPs.
The "Idea" is to extend and let administrators pick up properties also from different PropertySets.
tmoney2007
I figured you did.  I agree that all of the property sets should be available to map.  I don't think you should have to map the physical properties into Custom iProperties to pass them either.
ihayesjr
Status changed to: Accepted
Senthil_Kumar
Thanks for sharing your Idea. We use this forum to guide product development and help users in the best way we can, based on voting. We occasionally merge Ideas or archive old ones to keep the forum working properly - it ensures there is room for people to review new Ideas and that the most relevant and meaningful ones can gain votes. We’re archiving this Idea because it's been on the board for well over 2 years and hasn't received many votes from the community. If you want to raise it again and try to gain more support, you're welcome to do so. We’ve found that pictures and mock-ups can help get concepts across and win more votes from other users. If you have questions or see a connection between this Idea and others, let us know - Vault Product Team.
Senthil_Kumar
Status changed to: Archived
