From what I can tell right now, users have very limited control over the visibility of file records in the Thin Client. You can either see all versions of a document or all Released versions of a document. Both options can lead to confusion based on workflow.
What if you want to only show the latest Released version of a file record? You can't do that - all Released versions are currently displayed. Worse, what if you use a lifecycle like the built-in Flexible Release Process and perform a Quick Change? Now you have two versions at a particular revision. The result can be something like this:
To provide better control over file record visibility in the Thin Client, I'd like to see the options for File visibility expanded to a total of four (from the two we have now). These four options would be as follows:
- Show all file versions
- Show all Released file versions (allow multiple versions at the same Revision)
- Show all Released file versions (show only the latest version of each Revision)
- Show only the latest Released file version
I think one and four are self explanatory. Two and three might be confusing to the user, but I think they're ultimately necessary. Option two would function like the current 'show only released' versions, and would lead to a list like the screen capture above. Option three would be new functionality, and would hide all Released versions of a particular Revision level except for the latest. This option would hide versions that had been superseded by activities like Quick Change, and so in the example screen capture above, version 6 of the file would not be visible in the Thin Client.
