Status change - Apply Button
Make a "Apply" Button in the Status Change Dialog.
For example
I must change the status from "in wok" to "check in" and then from "check in" to "ready to produce"
5 Comments
ihayesjr
Is there a reason why your transitions are not configured so that you can't go straight to "ready to produce" from "in work"?
hans_hydrac
Yes there is a reason.
We have several designers but only two of us are allowed to change the Status to "ready to produce".
For the "normal" Useres is this no problem because the are not allowed to set the Status "ready to produce"
But for the two users are allowed set the Status to "ready to produce" it would be very helpful.
philip.s
Senthil_Kumar
Thanks for sharing your Idea. We use this forum to guide product development and help users in the best way we can based on voting. We occasionally merge Ideas or archive old ones to keep the forum working properly- it ensures there is room for people to review new Ideas and that the most relevant and meaningful ones can gain votes. We’re archiving this Idea because it's been on the board for well over a year and hasn't received many votes from the community. If you want to raise it again and try to gain more support, you're welcome to do so. We’ve found that pictures and mock-ups can help get concepts across and win more votes from other users. If you have questions or see a connection between this Idea and others, let us know. - Vault product team
Senthil_Kumar
Status changed to: Archived
