This relates to AutoCAD/Inventor/Electrical/Plant/Revit templates that are Project specific
Typically Templates are managed on a Network Share.
Ideally in a multisite environment they would be managed in Vault.
However the current process requires the Vault User to manually update their local workspace which the Design tool templates are mapped to.
Solution is to automatically update the existing active project local workspace folders with the Project templates or catalogs or spec sheets (Plant) on every login without adding too much wait time or performance issues
There may be 100s of active projects that the user is not working on, which doesn’t require syncing, so checking the local workspace for active project folders is key for performance.
It assumes that the user has downloaded the Project Templates when joining the Project and has not deleted the local Project Folders
