Project Template syncing to local workspace
This relates to AutoCAD/Inventor/Electrical/Plant/Revit templates that are Project specific
Typically Templates are managed on a Network Share.
Ideally in a multisite environment they would be managed in Vault.
However the current process requires the Vault User to manually update their local workspace which the Design tool templates are mapped to.
Solution is to automatically update the existing active project local workspace folders with the Project templates or catalogs or spec sheets (Plant) on every login without adding too much wait time or performance issues
There may be 100s of active projects that the user is not working on, which doesn’t require syncing, so checking the local workspace for active project folders is key for performance.
It assumes that the user has downloaded the Project Templates when joining the Project and has not deleted the local Project Folders
10 Comments
john.stewart
Solution is to automatically update the local workspace templates on every login without adding too much wait time or performance issues
Tags (1)
You could utilize the 'workspace sync' to update templates.
john.stewart
My customer has 50 users and 2 million files in Vault. A typical Vault user has 40K files in their local workspace.
The scenario is that 2 template files have changed and need to be pushed to all Vault users
The workflow and process time to enforce a mandatory update for only 2 templates to 50 Vault users using Workspace Sync is not a work around that my customer will implement.
ihayesjr
Status changed to: Accepted
ryan
This functionality is exactly what is contained with "Vault Mirror Plus" (free for Vault Pro 2016); https://www.solidcad.ca/vault-toolkit/vaultmirrorplus/
mikeh4
In my opinion this is a JDI project for Vault.  I believe task scheduler could do what we want and then we push Task Scheduler to every PC and let it automatically do a get 1 time per day.  From what I've found is that Task Scheduler will only get "CAD Files" as in IPT, IAM, IPN, IDW.  It can not grab any other file types.  I just need the ability to get any file type from Vault via Task Scheduler.  If that could be opened up I think I could do a get on 1 folder and everyone would have the latest and greatest customization with much more confidence then relying on the users and I really don't want to run around to 50+ PC every time I tweak something.  Then I still have to make sure I didn't make a human mistake by skipping someone or getting side tracked and not finish one.  This comment to the idea's out there.
We really need this and there are many conversations on this dating back to 2007 or earlier like this one:
https://forums.autodesk.com/t5/vault-forum/scheduled-task-for-get-latest-version/m-p/1911082
This could help nearly every user of Vault/Inventor.  In my opinion this is the only way to manage Customization files @ templates.
Related Ideas:
2021: https://forums.autodesk.com/t5/vault-ideas/posibility-to-force-syncronization-for-certain-vault-fold...
2013: https://forums.autodesk.com/t5/vault-ideas/enhance-management-of-inventor-design-data-and-templates-...
Thanks All!
mikeh4
So this was accepted back in 2013.  Is it still on the backlog or did it fall off the backlog?
Regards!
mikeh4
steveh3
@ihayesjr
@dan_szymanski
Irvin and Dan...says this was accepted back in 2013.
What does that mean? Was it implemented or possibly backlogged? Or maybe incorporated into another solution?
Just curious...
This similar request is from the same time frame has 127 votes....
Thoughts?
Best,
Steve Hilvers
ihayesjr
@steveh3
Sorry, but there is a history of our Ideas in the wrong status. So I am fixing this one.
We do want to address this request but it is not currently planned.
