job processor causing more significant effects of when inventor is crashing
this is an idea and a fix combo...
it seems that running the vault job processor & working in inventor / vault at the same time on the same machine can sometimes cause a more severe affect when inventor crashes. (& often this will cause broken vault add-ins)
can we have a review of the process that is used for the job processor, or improve the utility so that is does not use the inventor process.
could i suggest that perhaps in the interum that it may be possible to program the job processor to detect that if inventor is started,  the job processor should pause and warn the user that the two should not be run at the same time.
8 Comments
ihayesjr
Status changed to: Accepted
Mark, it is recommended that the Job Processor not be used on the same machine as a designer. It should be running on a dedicated machine so that it has all the system resources to process the job without interference to the designer.
Mark_Wigan
thanks,
would you like to consider the ideas put forward to minimise the downtime to users.
would you like to make note of the requirements clearly in all documentation to minimise the downtime to users.
can you make recommendations to users how to carry out this without having to purchase additional seats of inventor and vault?
autodesk must review and improve functionality around this. i had 3 separate workstations installations currupted to the point that a full reinstall was necessary on each. i can give more detail should you require.
-thanks.
Mark_Wigan
currently i am setting up batch file / task scheduler to run job processor on user machine overnight. (when no other activity is being carried out).
requesting autodesk to review to potentially provide and document out of the box resources to allow users and admins to choose this scheduling from the job processor itself and from vault explorer config settings.
also note:
http://forums.autodesk.com/t5/Autodesk-Vault-Customization/Exiting-Job-Processor-Tip/m-p/3129408/hig...
re: vc2012 functionality review for job processor
Mark_Wigan
as part of the improved functionality we have been requesting please also consider the following post referring to error in job processing if files are managed by other server in replicated environment...
http://forums.autodesk.com/t5/Autodesk-Vault-IdeaStation/functionality-review-ability-to-take-owners...
ihayesjr
ihayesjr
Senthil_Kumar
Thanks for sharing your Idea. We use this forum to guide product development and help users in the best way we can based on voting. We occasionally merge Ideas or archive old ones to keep the forum working properly- it ensures there is room for people to review new Ideas and that the most relevant and meaningful ones can gain votes. We’re archiving this Idea because it's been on the board for well over a year and hasn't received many votes from the community. If you want to raise it again and try to gain more support, you're welcome to do so. We’ve found that pictures and mock-ups can help get concepts across and win more votes from other users. If you have questions or see a connection between this Idea and others, let us know. - Vault product team
Senthil_Kumar
Status changed to: Archived
