Item Classification
Item Classification
Any idea when item classification capabilities are coming into vault Pro?
items can be devided in to item categories and product groups. To idenitify an item within the group structure information must be added to the item  with specific characteristics. So each item has a summery of differtentiated characteristics
the characteristics attached to an item are depending on the productgroup code. So for every possible value in the productgroupcode a different set of characteristics is defined.
The characteristics in combination with the Item category and Productgroup code can be used to find a specific item.
Example:
Item Category    =             Axle
Product Group    =            Steering Axle
Classification
               Trackwidth                    =             1995 mm
               Springtrack                    =             730 mm
               Load                              =             120 kN
               breakdiameter                =             300 mm
Item Category    =             Hydraulic coupling
Product Group    =             screw coupling
Classification
               Pipediam              =             15 mm
               Persure serial        =             L
               Thread                  =             M18x1,5
7 Comments
a.de.boer
Community Visitor
Great Idea. This is missing in Vault Professional Smiley Very Happy
mvdberg
I loved this feature in Productstream Professional (Compass)
mbrandwijk
We need more kudos from different customers and uiers to het this on higher priority with Autodesk.
mbrandwijk
Please kudo this item as much as possible to get this on The agenda from Autodesk with priority
Regards
Mischa
Verstuurd vanaf mijn iPhone
jparks_79
It would be very nice of this were standard functionality
mbrandwijk
dreams come true. This summer we released full Classification functionality for Autodesk Vault.
We did this inside our product on top of Vault; Cadac Organice Vault.
See also this link to our webpage for more info.
https://www.cadac.com/en/themes/product-classification/
Product Classification in Autodesk Vault
Our Cadac Organice Vault solution allows you to lay out and secure product classification in a PDM system such as Autodesk Vault. By setting up one fixed set of metadata for all product types that must be completed, you create a uniform method for completing this metadata. The result? The possibility to search rapidly and to detect duplicates.
Once a product has been designed, all metadata and relations have been recorded, and 3D models and drawings have been made, one thing is certain: things must be changed. Product designs irrevocably lead to product modifications. This means changes of product metadata, relations and/or documents describing that product. To be able to implement these modifications in a controlled, structured and predictable manner, there is an important basic principle that must be honoured, namely product revision exchangeability. You will also not be able to control this process without a PDM system such as Autodesk Vault.
YounesYammouri
Status changed to: Archived
