Inventor FEA Supporting Files
In Inventor if I create an FEA analysis of a model the supporting FEA files are created and checked in with my model. If I access and open the file the Vault pulls my FEA files out along with my model. This is fine if I'm the one accessing the file. It becomes a problem when someone else (who knows nothing about IV FEA) opens the model and has to deal with the supporting files. Usually there is a lot of confusion on their part.
It would be best to some how "suppress" the FEA files until I need them. So, when someone else opens the model they do not need to "get" the supporting file (and ostensibly get asked to check them out).
6 Comments
In the FEA configuration, you can click "Do not create OLE links". The FEA-files are then not linked as 3rd party files, and are not checked into Vault.
ihayesjr
The issue above was with Vault COLLAB 2011. I don't know if it was fixed in 2013 or not.
PeteMaxfield
Hans is correct.
FEA  - > Settings -> Solver,
Uncheck Results: Create OLE Link to Result files.
If the parent model file has already been checked into Vault, I recommend checking it out, adjusting the FEA settings, re-saving, and the OLE links should be severed. If that does not work, head to
Tools -> Links
and break the links to the files.
Senthil_Kumar
Thanks for sharing your Idea. We use this forum to guide product development and help users in the best way we can based on voting. We occasionally merge Ideas or archive old ones to keep the forum working properly- it ensures there is room for people to review new Ideas and that the most relevant and meaningful ones can gain votes. We’re archiving this Idea because it's been on the board for well over a year and hasn't received many votes from the community. If you want to raise it again and try to gain more support, you're welcome to do so. We’ve found that pictures and mock-ups can help get concepts across and win more votes from other users. If you have questions or see a connection between this Idea and others, let us know. - Vault product team
Senthil_Kumar
Status changed to: Archived
