Edit Properties in 'Grid'
Add an 'Edit Properties' button, which will then 'activate' the properties grid to modify any of the 'user defined' properties.
This will be in place of utilizing the 'wizard' to update properties.
14 Comments
This is the best idea yet.
This is a great idea....need to do it.
This could be very useful.
ihayesjr
Status changed to: Accepted
Do you currently have the Properties grid closed during day to day operations?
Typically, our users have the grid always open.
ihayesjr
Another question, you can add the "View Properties Grid" as a button on the toolbar.  Do this solve your request?
ihayesjr
Status changed to: Archived
No.  The new idea is, to activate the grid to edit the property values directly in the grid.
This is in place of the current process, with the 'wizard'.
For example, be selecting the 'edit properties' button, the 'grid' is than activated so the values can be modified for the listed 'user defined' properties.
iqbal_lotey
hey this is a fantastic idea, somone needs to fix the status because a solution has not been provided
ihayesjr
scottmoyse
Exellent. I have wanted this to be like the AutoCAD properties grid since the first day I used Vault Pro.
YounesYammouri
Did you guys had chance to use Autodesk Vault Data Standard for Vault 2016?
Edit Datasheet dialog will give you such capabilities. You are able to edit all user defined properties in such Grid.
Select Edit File Datasheet, following dialog appears (No wizard)
Pre-request: you need to install Autodesk Vault Data Standard for Vault 2016.
Younes
YounesYammouri
