DWF is out of date / not system controlled
We are using VP 2013 and Dynamics Axapta in our company. We export complete BOM's with DWF files to DAX. Problem is that you don't know if DWF is out of date or system controlled(made by job server). So before release we check the top of the BOM with the pack and go function. This gives you an answer if the DWF are out of date. We then have to send the out of date files to job server for a new file.
Could there be a function that said check DWF files to the BOM before release? And if the BOM has files that are out of date or not system generated, send the complete list to job server for update.
3 Comments
ihayesjr
Status changed to: Accepted
Senthil_Kumar
Thanks for sharing your Idea. We use this forum to guide product development and help users in the best way we can, based on voting. We occasionally merge Ideas or archive old ones to keep the forum working properly - it ensures there is room for people to review new Ideas and that the most relevant and meaningful ones can gain votes. We’re archiving this Idea because it's been on the board for well over 2 years and hasn't received many votes from the community. If you want to raise it again and try to gain more support, you're welcome to do so. We’ve found that pictures and mock-ups can help get concepts across and win more votes from other users. If you have questions or see a connection between this Idea and others, let us know - Vault Product Team.
Senthil_Kumar
Status changed to: Archived
