Show only
Search instead for
This is possible. Select both files you want to copy and paste between (or 1 of them if they are in different folders).
Edit Properties (3 methods)
Ctrl + E
Edit menu > Edit Properties
Properties Panel on the right > Edit Properties button
You can then add fields and other files. Then Copy, Paste, Capitalize, Find, and Replace.
It's true that it's not a simple Copy Paste method but it's very powerful and you should check multiple properties are correct while you're there anyways.
ADDENDUM - I just realized that you said, items (not files). I don't use items in my vault so I can't test but hopefully the method above works.
