Combine a series of tokens in a search
I would like to see the ability to combine search tokens into a specific string to search against.
IE, if my description is 'CV axle line 5F/6G' I do NOT want it to appear if I search against:  Description contains Line AND  "5G"
Adjusting slop factor in web.config would lead to some results not showing; exmple if description is 'CV axle line 1B/1C/4D/4F/5G'
Thanks!
4 Comments
ihayesjr
Status changed to: Accepted
n.hall
It would also be good if you could search for the tokens in the order they are entered
IE if you search for 123 456 789
You would get 123-456-789, but not 456-123-789
Senthil_Kumar
Thanks for sharing your Idea. We use this forum to guide product development and help users in the best way we can, based on voting. We occasionally merge Ideas or archive old ones to keep the forum working properly - it ensures there is room for people to review new Ideas and that the most relevant and meaningful ones can gain votes. We’re archiving this Idea because it's been on the board for well over 2 years and hasn't received many votes from the community. If you want to raise it again and try to gain more support, you're welcome to do so. We’ve found that pictures and mock-ups can help get concepts across and win more votes from other users. If you have questions or see a connection between this Idea and others, let us know - Vault Product Team.
Senthil_Kumar
Status changed to: Archived
