When batch plotting inside Vualt Client, I would like the option to plot individual Autocad drawings to a single PDF file. Currently, Inventor drawings will do this automatically, since the sheets are a set within a single idw file. With Autocad drawings, however, we often have projects that may contain as many as 36 individual dwg files. Even if these are controlled by a sheet set or an Acad Electrical project, they batch plot from Vault Client as individual pdf files. These, then, have to be manually compiled into a single pdf for transmittal to customer, vendors etc.
The option, (checkbox perhaps) to compile them into a single pdf right in the plot window, would be a tremendous time saver.
Thank you!
