Description
Autoloader allows user to remove documents with issues after a scan. These documents remain in the same folder as the documents without issues that are loaded into Vault
Impact
Reloading the documents with issues requires finding and fixing broken relationships\x-refs etc.
The documents with issues are stored in the same folder as successfully loaded files.
Requires exporting the report of issues and manually extracting the files for the Dataset for reprocessing
Severity
High/Critical
Solution
When files and their associated files with issues are removed from the scan list, move these files to a redo folder so the User can repair the broken relationships\x-refs and then Autoloader this delta folder.
