Ability to print "Copy Design"
In the "Copy Design" dialog, I would like the ability to print this after I get all the changes made and the files renamed, but before I hit the "OK" button.  If what I am doing is small enough, I can just do a screen capture, but on a large project that does not work.  It would be good just for a record to know where the parts were copied from and if something goes wrong during the copy design (after I hit the "OK" button), I can easily redo it.  It is so frustrating to have the copy design fail after spending an hour getting the files the way you want them.
5 Comments
ihayesjr
ihayesjr
ihayesjr
Status changed to: Accepted
Senthil_Kumar
Thanks for sharing your Idea. We use this forum to guide product development and help users in the best way we can, based on voting. We occasionally merge Ideas or archive old ones to keep the forum working properly - it ensures there is room for people to review new Ideas and that the most relevant and meaningful ones can gain votes. We’re archiving this Idea because it's been on the board for well over 2 years and hasn't received many votes from the community. If you want to raise it again and try to gain more support, you're welcome to do so. We’ve found that pictures and mock-ups can help get concepts across and win more votes from other users. If you have questions or see a connection between this Idea and others, let us know - Vault Product Team.
Senthil_Kumar
Status changed to: Archived
