Hi All
Hoping you could help...
During working with vault users are often getting the following error:
A problem occurred while attempting to retrieve folder information from the server.
The server returned the following information: Your account has been automatically logged out of the Autodesk data management server. You must log in to access the vault.
We had this error a few months ago and did a reinstall and restore, and vault has been working fine since then. This has now popped up again. Don't want to do that again as our database is so large we will need a good few hours.
Using Vault Professional 2011 Thanks all, below are the errors we are getting....
Vault Explorer Error:
AutoCAD Error:
Inventor Error:
As I understand it, Vault automatically logs you out after access to it has been idle for 30 minutes, in order to free up that lisense for another user.
IV 2011 SP2 is supposed to take care of that in Inventor, so you don't get logged out and lose access to Content Center, for example. But as far as Vault client or AutoCad, I'm not aware of anything that prevents this from happening.
Chris Benner
Inventor Tube & Pipe, Vault Professional
Cad Tips Tricks & Workarounds | Twitter | LinkedIn
Autodesk University Classes:
Going With The Flow with Inventor Tube and Pipe | Increasing The Volume with Inventor Tube and Pipe | Power of the Autodesk Community | Getting to Know You | Inventor Styles & Standards |Managing Properties with Vault Professional | Vault Configuration | Vault - What is it & Why Do I Need It? | A Little Less Talk - Tube & Pipe Demo | Change Orders & Revisions - Vault, Inventor & AutoCAD | Authoring & Publishing Custom Content
Thanks for the reply.
I will make 100% sure that SP2 is installed, but think I have done that. As you said, this fix helps Inventor, it's the logging out of Vault Explorer I am really worried about.
Another Issue on the server is that opening up ADMS console can sometimes take longer then an hour, even after a server restart. I am not sure what is causing this delay.
No, I'm not sure what's causing that delay either, you may need to get some bonifide tech assistance on that one.
Chris Benner
