We have over 50,000 autocad files to load into Vault Collaboration 2011. I planned to use Autoloader but many of the files are R13 still which is not supported by Autoloader. I figure I have to use the Check In Folder option within Autocad because of the R13 restriction?
Currently our XREF's are stored on a network drive.
When attempting to load files with XREF's, it does the following:
I don't want it to create a XREF directory. We already have a directory containing all the XREF's within Vault:
How can I "map" the XREF's to the Vault XREF directory?
Or is there a better solution altogether? I don't fully understand what Vault does with XREF paths.
Secondly, what should be done about other support files that currently load off the network drive i.e. fonts, plot styles, plot configurations? Should they be loaded into Vault or should we maintain a network drive just for these?
Thankyou
Solved by junyi_zhu. Go to Solution.
Please ignore the Second question in regards to plot styles and fonts. They are not run from a network drive as first thought.
From your screenshot it looks that you want the xrefs go to library folder. If the "Lib" folder in vault is indeed a library folder, you can map it or its sub folders to the network drive where your xrefs reside. After that you should see the check-in dialog puts them under the mapped vault library folder.
