In Vault Pro 2013 I'm using items, based on Inventor files.
The items in the BOM have a different unit then the quantity value used in Inventor:
Inventor = mm
Item = m
When assigning items the value of the Inventor file is used with the unit of the item!
So, 125mm in Inventor = 125m in item. But the item Qty value has to be 0,125m.....
Changing the value manually helps, but is lost after an item update and the value has is originally wrong value again.
See also attached images.
What is going wrong here?
Cheers, Danny
