When I save my assemblies, often times in the "Save" column some of the files will have "Yes (Write Enabled) in that column. I go ahead and save. Now in the Vault browser, those parts have the green dot by them (Local copy edited out of turn, use Check out). Now I have to right click on each-and-every part that has this icon and select "Check Out".
Question is, why does Vault not go ahead and check these files out when I save the assembly? Is there any way to avoid have to select each file?
Vault 5, Inventor 10
