Vault WorkGroup....One of my users clicked on the Workplace Sync button, the system began to run and sync. The problem is it deleted everything that wasnt vaulted. Thats a major problem! All his work he had been working on is now gone and Vault Worgroup deleted it from the computer and not put in Recycling Bin. Is there some sort of recovery? I cant thing that one button would delete anywork that is not vaulted on the local computer. any Help?
When workspace sync, you can config the settings how to sync the files.
And it will also show you a list of the file which will be removed, overwrite, download and you can check/uncheck before procceed, but if you found you mistook some files deleted, you should be able to find them in Recycling Bin unless you disable the recycling bin in your computer.
