I am trying to check out a previous version of a Part file for Inventor 2011. It will not allow me to do it.
It won't allow me to place the check mark so I can get the file.
Any ideas?
Solved by achintam. Go to Solution.
It will only allow you to 'Get' it? Is the document 'released'?
You can only check out the latest version of a file. However, you can use the following workaround if you need to revert to a previous version:
http://crackingthevault.typepad.com/crackingthevault/2009/07/howto-revert-to-a-previous-version.html
