Vault Forum
Welcome to Autodesk’s Vault Forums. Share your knowledge, ask questions, and explore popular Vault topics.
Windows Authentication failed
12 REPLIES 12
Message 1 of 13
Rene-J
2029 Views, 12 Replies
Hi
We have this issue with Vault Windows Authentication. this messagebox is shown
with users (Please make sure you are in the same data management server).
It was starting when we upgrade to vault 2014, and we still have this issue when we update to vault 2015 sp1. it is happened nearly every 3 week. and it happened always after weekend.
I think it is something to do with dns, if I change the servername to ip adresse it is working.
I have try to restart iss. But it is still the same. The only thing that is working, is restart server.
I have found this old link.
http://forums.autodesk.com/t5/vault-general-discussion/windows-authentication-component-broke/td-p/3...
The suggestion is to set DefaultAppPool regular time to interval to (17400)
My settings is set to (1740) Vault server is Windows server 2008 R2 IIS 7
Can I still using this old link and change 1740 to 17400 and what does this or is there other suggestion ?
René J
12 REPLIES 12
Message 2 of 13
herrerh
in reply to: Rene-J
For your issue, when this occurs, can the client and the server still resolve the servername by IP?  It certainly sounds like a DNS/Name resolution issue.
-Hywell
Hywell Herrero
Data Management Support Specialist
Product Support
Message 3 of 13
Rene-J
in reply to: herrerh
When it happens, I can ping the server name without any problem.
René J
Message 4 of 13
Rene-J
I fogot something, If I Login as Administrator or another username without using Windows Authentication then ther is no problem.
I think it something to do with IIS and Vault Windows Authentication.
René J
Message 5 of 13
mikegreslick6607
in reply to: Rene-J
We are having the exact same problem. The only difference is that I get my Windows Auth error on the 4th of every month. As above, i can use the IP address and everything works well. IIS restart doesn't work.  We can still ping the server by using the IP address or the server name successfully.  Also, logging in without Windows Auth works.
A few other notes that my reseller had me check:
  • There are no requirements that each user resets their password every 30 days
  • No group policies set to run every 30 days (or any group policies at all for that matter).
  • Other reboots have no effect on this (we just rebooted for other reasons last week, but we still got the windows authentication error today as expected)
Any solutions at all to this?
Message 6 of 13
Rene-J
in reply to: mikegreslick6607
Hi
Thanks for sharing info.
I think it is some thing to do with "vault maintenance"  we have a schedule that run every saturday 20.00
maybe you can check on your server, when you are running the vault maintenance script.
but I need to confirm that I am right.
I think, I have a server, that will have this problem this weekend.
I think, I will test before the maintenance script is running and after.
René J
Message 7 of 13
bjzhangzx
in reply to: Rene-J
Try to change the C:\Windows\System32\drivers\etc\hosts file and add a static DNS record for your server.
I have also experienced some weird situation where the ping-server-name thing seems OK but you just cannot log in, the trick above finally solved the problem for me.
Message 8 of 13
tmoney2007
in reply to: Rene-J
Let me ask around. We had this issue a while back with Pro 2013 but it has gone away.
Message 9 of 13
Neil_Cross
in reply to: tmoney2007
Do you have Windows Authentication enabled on your Default Website?
I'm not sure if it propogates down, but also ensure it's set on the AutodeskDM site:
Then do an IIS reset and see if it helps.  If not, then it's likely one of the other IIS settings.  Like tmoney I've had this issue previously, but at the time it was one of those cases where you go over every setting changing multiple things until it works, but then you don't know which one did the job!
Message 10 of 13
Neil_Cross
in reply to: Neil_Cross
Apologies just ignore all of that, just re-read the original post and it said when using IP address it works OK.  So it probably won't be anything to do with the above.
Message 11 of 13
tmoney2007
in reply to: Rene-J
Our main DBA is on vacation this week (the one that knows how we fixed this). Either no one else knows or is too busy praying that nothing goes wrong while he is away.
Message 12 of 13
It looks like Autodesk may have found a solution to this.
http://knowledge.autodesk.com/support/vault-products/troubleshooting/caas/sfdcarticles/sfdcarticles/...
I changed the settings on our server today, so let's hope this is the fix!
Message 13 of 13
Rene-J
Hi
this http://knowledge.autodesk.com/support/vault-products/troubleshooting/caas/sfdcarticles/sfdcarticles...
doesn't work
But I think I have sloved the issue
in our vault maintenance script
we have a IIsreset before run maintenance
I have changed this to run after instead of.
It seems to work, the error should have been in this weekend, but it doesn't.
Rene J
