Vault General Discussion
Product Support
20 Kudos
Post 11 of 17
Re: Windows Authentication component broke???
03-20-2012 07:56 AM in reply to: lypatric
If it works via IP address and not the host name then your issue is most likely a network issue.
If you do a "ping <hostname>" do you get the same IP address?  Check with your IT group for help with this.
Hywell Herrero
Data Management Support Specialist
Product Support
1 Kudo
Post 12 of 17
03-21-2012 04:29 AM in reply to: herrerh
Thanks for reply.
The "ping" works, with IP address or server name.
Member
0 Kudos
Post 13 of 17
02-26-2013 08:03 AM in reply to: lypatric
Hi!
is there a step by step guide for reinstalling the IIS?
I have the same problem after installing sp2 for Vault Pro 2012.
The IIS roles are configured corectly, so I must reinstall the iis.
Thanks.
Fotis
Valued Mentor
40 Kudos
Post 14 of 17
09-23-2013 05:26 AM in reply to: lypatric
I just upgraded from Vault Server Pro 2013 to 2014.  We applied SP1 after the upgrade and we are unable to login to the Vault Explorer using the server name at our subscriber site in Poland.  We can login using the server IP address.  Can you provide me with detailed instructions on how to fix this issue?  Thanks!
John C Weiss Jr.
CAD Administrator
Follett Corporation
New Member
0 Kudos
Post 15 of 17
09-24-2013 10:38 AM in reply to: lypatric
Having the same issue here.  Upgrading 2012 Vault AEC to 2014 Pro, SP1.  can login with IP, but not server name.  Can ping both IP and Name.  can you provide step by step instructions to resolve this?
Active Contributor
1 Kudo
Post 16 of 17
12-03-2013 05:48 AM in reply to: herrerh
One of my customers has a similar problem after updating Vault Pro 2013 RTM to SP1 Update 2.
Vault login works but not Windows authentication. Tried the steps in various cracking the vault articles, but still no success.
Any other help would be appreciated.
Cheers
Dan
Active Contributor
0 Kudos
Post 17 of 17
01-19-2014 11:30 PM in reply to: Studioworx
Anyone solved this? Vault 2013 Collaboration - Win Auth worked well but then sudenlly stopped.
New button for Platinum & Gold Subscription customers
Gold & Platinum Subscription customers can alert Autodesk if they require assistance with their forum post
Manufacturing Community
