I Use Web Client of VltCollaboration 2011. ADMS on Win2008Server, SQL Express 2008.
I'd like to know if it's possible to get a logfile, to know who logged in/out the Web Client.
Any idea ?
Thanks in advance.
Solved by chearhuat. Go to Solution.
The logging of the IIS server should contain this information.
I will look on our server if and where to find this. I will let you know if I have the information
Hi idubail,
Currently, Vault does not provide any out-of-the-box tools to monitor user log in/out activity.
You might wish to look into IIS, or SQL Server native log for the required info.
Chear Huat.
Thanks for information !
You're right :
you can find IIS Log here :
C:\inetpub\logs\LogFiles\
or here :
C:\Windows\System32\LogFiles
Import it in MS Excel, then Fiter colum, and see Username and IP Address, like this :
Thanks again for the tip !
I. Dubail
