with lmutil_x64.exe lmstat -a -c @server i can see which user has a Inventor-licence, but not who has a Vault-licence. You see only how many Vault-licence are in use.
How can i see who has a Vault-licence?
Best regards
Michael
Solved by swalton. Go to Solution.
you should be able to run a status inquiry on flex lm
DarrenP
do you mean the function in the LMTools > Server Status > Perform Status Enquiry?
This shows me the same.
User of the Vailt-Licence is always the Server, you can not see wihich client has the licence.
thats right
i don't think you can with vault since the licensing works differently
DarrenP
When a user connects to Vault, it is the ADMS that get's the license, and then provides connectivity to the client.
yep thats correct
DarrenP
If I remember right, one of the ADMS log files records license status. You might be able to write a script that scans throught the file and gives you a nice list of who has a license.
I am not aware of a nice list from ADMS about which users are consuming a license.
Steve Walton
thanks for your answer.
I found the log-Files.
If anybody search this: Every day is made a new log-file under:
C:\ProgramData\Autodesk\VaultServer\FileStore with the name vlog-20120217.txt par example.
Best regards
Michael
i made a WSH-script to read out the which users has a Vault license in use.
On the server you have to share the Folder C:\ProgramData\Autodesk\VaultServer\FileStore
I start this with a Batch-script, in this i read out with other FlexLM-License are in use.
if you want to use this in a batch file, you can start ist with "cscript.exe vault-license.vbs" an the output comes on the command line.
Best regards
Michael
Being placed to "C:\ProgramData\Autodesk\VaultServer\FileStore" of ADMS and executed it reports "Pfad nicht gefunden" which I guess means "Path not found".
So there are a lots of vlogs just around but it can't see them...
Any ideas?
...Added later....
Ok I've fixed it a bit
instead
PfadLogfile = "\\SERVER\FileStore\"
printed
PfadLogfile = "C:\ProgramData\Autodesk\VaultServer\FileStore"
And it returned the list of successful attempts for license.
But it is not the list of users who use license right now. Isn't it?
Michael,
I wonder would it be easier for you as for script author add some filtration (skip all same user/same PC lines except the latest)?
Hello uma,
i don't understand what you mean.
What is the output of the script?
What is in the vlog*.txt (in the lines with "Acquired license")?
Hello uma,
that looks interesting.
I don't know why does it not work for you. In our case ist works.
The output looks strange. Par example that the administrator is always 2 times in the list in the difefrence of 1 second.
Is that in the vlog*.txt the same?
The script works. Just the info it returns is far from ideal (too much).
What for It lists all the user acquires?
Only latest request from particular User and particular Host are interesting.
Doubled request are present in vlog itself and could be a result of oue add-in. I'll investigate but that is not the main problem.
