Show only
Search instead for
From time to time you need to clean out the local (C: drive) Vault directory. Is there a way of seeing which files are tucked away securely in Vault on the server?
I have lost work several times by clearing out the local Vault only to find that one of the files was something I wanted and wasn't checked in 😞
First do a search for OldVersions and delete all
the results. Then do another search on your workspace (leave the filename fields
blank). This will bring up all files in your workspace no matter how deeply
nested they are. Add the Attributes property to the search results window and
sort by Attributes. Anything that's not Read Only isn't in the
vault.
