Vault Forum
Welcome to Autodesk’s Vault Forums. Share your knowledge, ask questions, and explore popular Vault topics.
Where to find the Reference Repair Utility
8 REPLIES 8
Message 1 of 9
2028 Views, 8 Replies
Where to find the Reference Repair Utility ?
8 REPLIES 8
Message 2 of 9
SBix26
Looks to me as if this is a Vault question-- perhaps try the Vault forum?
Sam B
Inventor 2012 Certified Professional
Please click "Accept as Solution" if this response answers your question.
Inventor Professional 2013 SP1.1 Update 1
Windows XP Pro 32-bit, SP3
HP EliteBook 8730w; 4 GB RAM; Core™ 2 Duo T9400 2.53 GHz; Quadro FX2700M
SpaceExplorer/SpaceNavigator NB, driver 3.7.18
still waiting for a foreshortened radius dimensioning tool in Drawing Manager
Message 3 of 9
marina.collet
You have to install SP1 for Vault 2013, or SP2 for 2012.
Then, on the client computer, you'll find it here:
Windows Start Menu > All programs > Autodesk > Autodesk Data Management > Tools > Autodesk Reference Repair Utility
Message 4 of 9
mbaker
in reply to: marina.collet
Apparently I have lost my mind, I'm running Vault Pro 2016 on Windows 8.1, I cannot find the "Reference repair utility" on this system anywhere. Does it exist for 2016, does it require a server Op-sys, SP1 or something. I used it in the past, but have completely forgot where it is located.
Thanks in Advance...
Mike B
Message 5 of 9
mbaker
Thanks, But the client is currently running Vault 2016...
Mike
Message 6 of 9
marina.collet
in reply to: mbaker
Hi Mike,
You're right it does not seam to be in the Win 8.1 Applications any more...
However, you can browse to the exe, from my experience it still works.
The exe is in the Vault Explorer folder, in my case it is
C:\Program Files\Autodesk\Vault <flavour> 2016\Explorer
Search for "ReferenceRepairUtility.exe"
Message 7 of 9
mbaker
Hi Marina,
Thanks a bunch, I seriously thought I was loosing it...<grin> Now that all is clear I'll check this out, and I can get the this little problem cleared up...
Thanks Again
Mike
Message 8 of 9
mbaker
Marina,
Worked as expected, thanks for the help
Mike B
Message 9 of 9
AndyWallace
FYI, the Reference Repair Utility executable seems to be gone, from the 2018 release anyway.
It may be because "update file references" is a Vault command now.
Andy
Andy Wallace
Autodesk Inventor (2016) (3 years)
previously Solidworks (6 years)
