Searched and searched....then searched some more. Where can I download Vault Server Basic 2015?
Damon
Solved by Jason.Courtemanche. Go to Solution.
That depends on how you bought it. Did you buy it on susbscription? If so you can go to the Virtual Agent for all downloads. Did you go through a reseller?
Chris Benner
Inventor Tube & Pipe, Vault Professional
Cad Tips Tricks & Workarounds | Twitter | LinkedIn
Autodesk University Classes:
Going With The Flow with Inventor Tube and Pipe | Increasing The Volume with Inventor Tube and Pipe | Power of the Autodesk Community | Getting to Know You | Inventor Styles & Standards |Managing Properties with Vault Professional | Vault Configuration | Vault - What is it & Why Do I Need It? | A Little Less Talk - Tube & Pipe Demo | Change Orders & Revisions - Vault, Inventor & AutoCAD | Authoring & Publishing Custom Content
Maybe I am confused. We are moving all of our suites to subscription. We setup a test Vault Basic Server 2014 in the Spring and tested with our 2014 clients. We now are on 2015 and the clients are no longer compatible
"Vault Basic 2015 19.0.49.0 is not compatible with......Vault Basic Server 18.2.2.0"
I've not been able to find much documentation on Vault Server 2015 to get a clear understanding of what has changed and how to plan for a new Vault Server 2015. As I understood it, the Vault Server 2014 was free and each client lic. is either bundled with our suites or we purchase addition lic. Has this pricing structure now changed?
Damon
Your post has me a bit confused, but it is early and my coffee is still kicking in...
You upgraded your suite to 2015... did you also upgrade your Vault server to 2015? All of your seats of Vault Client are 2015? The numbers suggest that maybe you (without knowing it) loaded a service pack for the client without loading the same SP for the server? I'm just tossing out ideas here. We need Darren... Darren are you out there?
Chris Benner
"You upgraded your suite to 2015... did you also upgrade your Vault server to 2015? "
Yes to the client upgrade to 2015.
No to server 2015.....this is what I'm trying to do.
I'm trying to find the software for Vault Server Basic 2015 (which would not require a serial number and activation key). When I installed Vault Server 2014 in a test environment I did not need a serial number and activation key.
Is there any documentation on the different variations of Vault Server 2015?
Damon
You said you upgraded to subscription, if so you can get your server download from the Autodesk Virtual Agent. If the Vault Server was a part of your Suite, then the Serial number and Key from the Suite should be all you need.
Chris Benner
to make things easier just download the Vault 2015 Server from here:
You can access most current + previous supported version Browser Download links (including the Design & Creation Suites) through Matt, Autodesks Virtual Assistant. http://autodesk.creativevirtual15.com/autodesk/bot.html?isJSEnabled=1&businessArea=Root.Front%20Desk...
>download links>Vault Products>Vault Basic Server
Please accept as a solution if this fully resolves the issue
for whats new in Vault 2015: http://help.autodesk.com/view/VAULT/2015/ENU/?guid=GUID-EB291E0F-816C-4C35-AAB8-1E6DF96DDB2F
Vault Basic is still a free product
DarrenP
Thanks for the links.
Just to be clear.....if I have four users two on basic and two on workgroup, I would install workgroup server using one of the workgroup client serial numbers and key codes?
you can't mix & match vault editions
the vault basic clients will not talk to a Vault Workgroup server this is as designed there are no workarounds
DarrenP
@Anonymous
Vault products have been removed the Autodesk Virtual Agent. Instead log into your Autodesk Account and select Product Enhancements. Somewhere on the list will be the Vault basic server and client down.
Mark Lancaster
& Autodesk Services MarketPlace Provider
Vault Basic download has been moved to fall under the product in which it is available. Please find a quick 40-second or so video that shows where Vault Basic products can be found. AutoCAD Electrical was used in this video, but all products containing Vault Basic as a subscription benefit should be the same.
