In Inventor's Vault browser addin, one of my files was stricken through and Check In was disabled. I pressed "Refresh Vault status" and the strikethrough went away and I was able to check in the file. What caused the strikethrough?
That meant that someone else had the file checked out.
According to "Autodesk Vault File Status Information" (attached), bold and grey means someone else has checked it out. Is the strikethrough documented anywhere?
If you are using Vault 2012 strikethrough is now being used by default to signal someone else has the file checked out. It looks like that pdf was not updated in the final build.
Ah just reread your initial post. Strikethrough in the Inventor browser means the part was suppressed in Inventor.
