Hello;
I'm using Inventor and Vault Pro 2014. Loaded Inventor assembly. Set the toggle switch above the assembly browser to "Vault". Several subassemblies have an astrisk beside the name in the Inventor assembly browser.
What does this astrisk mean?
How can the condition causing the astrisk be resolved?
Thanks.
It just means they need a save before they can be checked in. If you try to check in it will prompt you that some files need to be saved. I realize you may have just opened the files, but.... it happens. Might be something that got updated in the bachground that requires a save.
Chris Benner
Inventor Tube & Pipe, Vault Professional
Cad Tips Tricks & Workarounds | Twitter | LinkedIn
Autodesk University Classes:
Going With The Flow with Inventor Tube and Pipe | Increasing The Volume with Inventor Tube and Pipe | Power of the Autodesk Community | Getting to Know You | Inventor Styles & Standards |Managing Properties with Vault Professional | Vault Configuration | Vault - What is it & Why Do I Need It? | A Little Less Talk - Tube & Pipe Demo | Change Orders & Revisions - Vault, Inventor & AutoCAD | Authoring & Publishing Custom Content
Following settings minimize automatic updates on components.
Applications Options -> Physical Properties
Applications Options -> Save -> Prompt to save for re-computable updates (checked)
Applications Options -> Content Center -> Standard Parts Refresh out-of-date..... (Un-checked)
