How can I restrict the web client user to be able to see drawings only and not parts & assemblies.
Also, when we say drawings, does he actually need to be restricted to view dwfx files or IDW?
Need little advice here.
The best way if to use categories. Categories allow you to apply Revision schemes, Lifecycle states and different property rules to a given set of files based on Rules (if you wnat categories to be automatically assigned). I have different types of idw's categorised differently based on an iProperty marker that has to be filled in before its saved (you can use iLogic to enforce this, or iPropWiz (but that has some loopholes)), then on checkin the file is categorised correctly. Using this technique you can create a lifecycle release process that will restrict a user belonging to a predefined group from viewing files within the web client. One thing to remember with the web client, is that only displays 'Released' files anyway (unless you log into the web client as Administrator, from memory, or there may be a global setting somewhere).
As a result you can control which files a web client user can view if you have your drawings using a different lifecycle release process than you parts & assemblies etc..
Scott Moyse
Design & Manufacturing Technical Services Manager at Cadpro New Zealand
Co-founder of the Grumpy Sloth full aluminium billet mechanical keyboard project
In my case I am trying to restrict part models but allow to read idws. So, I categorize ipt & idw differently, then from your approach, they both will be in different lifecycles. I think they always will be in same lifecycle and both will be in released state also. When they are released, there should be a way to restrict viewing part files. Do you have this differently?
Like you said, if I add a flag " Read by Shop : Yes or No" and capture this info as Yes for ALL idws. How can I show only file s those have "Yes". May be I am missing to understand something from your response.
If you don't want the shop to ever see the part files but always see the idw's, but you want them both to follow the 'same' lifecycle then you need to do the following:
Set up your lifecycle release process how you want it to be (you probably already have one)
Then copy it and name it Part Lifecycle release process (or something similar), then edit it and go to the Released state and modify the security settings for that state. Hopefully you have a specific group set up for your shop guys, then you can deny them to right to view the part files in this released state. If you don't have a group (not advised, you should always have groups set up) then you can add the individual users to the security group and deny them the right to view them.
Please note, that not allowing them is the same as denying them. However, you may have everyone set as Read allow on the released state security, simply by adding the 'Shop' group (or username) but then not ticking any boxes based on my previous statement you would think it denies them access, but it doesn't, because they haven't been explicitly denied, whereas they have been allowed via the everyone security rule.
My point here is that if you have a user that is a member of two groups, say Design & Scheduling, then you give design explicit access to read a file in the released state, but at the same time explicitly deny the scheduling group read access. Then the result will be that user won't have read access, because Vault (& windows networking security) will prioritise a Deny over an allow. As a result you are better of 'Not allowing' to deny a group (by not ticking anything) than to explicitly 'Deny' a group from something.
So its likely that if you have a default out of the box lifecycle in use for your parts & drawings, that the Released state will have a security setting of Everyone: Read 'Allow', Modify 'Deny', Delete 'Deny'. If this is the case you will want to remove the Everyone 'group' and then add just the users/groups you want to have Read permissions and Allow them but don't deny modify or delete. This woudl give you the settings you need for the 'Parts' lifecycle release process.
Now if you want to add this process to all your part files automatically you will need to create a category specifically for parts, and use a rule like, file ends with ipt. Then as soon as a new part is added to the vault it will get categorised to the part category which has the default lifecycle you have just created.
I hope this helps.
Scott Moyse
Scott,
Thanks for explaining this so in-detail. So far I follow it fine & dont have questions. I will try this first thing in the morning. Cheers ! Have a great day.
